1- Sorry ... What do you mean by " (J) join-command is not working " ?!! :cara_con_una_leve_sonrisa:
2- We wish to know how it's changed ( as you said) ?!! But you may need to check PICKSTYLE (System Variable) also it's good to know Commands for Working With Groups Here
3- For multiple copy you have to check the mOde option in copy command .
Command: COPY
Select objects: Specify opposite corner: 1 found
Select objects:
Current settings: Copy mode = Multiple
Specify base point or [Displacement/mOde] <Displacement>: O
Enter a copy mode option [Single/Multiple] <Multiple>:
Imad Habash
