morten.eriksenAPTEP
901 Vistas, 2 Respuestas
AutoCAD 2021 - Commands not working properly as before
After installing Autocad 2021 I have issues with commands that worked perfectly on previous versions.
1. The (J) join-command is not working for me at all.
2. The (G) Group command has been changed so I need to do many more steps to make a group.
3. Normal (CO) copy-command I usually had set to "Multiple", but it is now stuck on single, even when I change it. I therefore have to use (COPYM) for the same functionality, which takes more time.
I use this commands a lot and would love some help to fix these issues.
NB! I run Windows 10 64-bit edition and AutoCAD 2021
