- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hey Cheryl,
Thank you for the reply.
I've attempted audit and purge when this problem occurs but this doesn't seem to fix the problem for me. Audit finds nothing
AUDIT doesn't pick up any errors for me (perhaps a bug of the version I am using?) and PURGE only removes data not in use. I have discovered that it will typically happen after I isolate and unisolate layers or objects - then all associated VIEWBASE views are highlighted as out of date. As soon as I update the views all the dimensions can no longer interact with the 2D projection as normal, they can only select o-snap points once and refuse to become re-associated.
Drawing functional
Drawing that is about to become broken
Drawing broken
Moving the solid in model space has only displaced views in Layout but never caused them to break in this way. Sometimes this resolves by selecting another object in model space then selecting the original but this has seldom been successful.
