Kent1Cooper
en respuesta a: Beka_Tchigladze
"Impossible to notice" is not the same as "distorted."  I was looking mostly at the edges of the sign, which didn't look bad.  (And I do wonder why it's skewed at a slight angle, which can make lines or edges look a little bit stepped, depending on screen resolution, etc.)
Are you letters and frames edged with bordering Polylines or something, in the same green color as the sign surface, so that any lineweight on those borders would overlap into the white areas?  [A drawing file would answer this.]
Kent Cooper, AIA
