1wildwes
en respuesta a: ggtoutounji
In the original drawing, put the xref on a specific layer, preferably a layer only used for xrefs, like C-XREF. Set your layers as desired. Set your current layer to 0. Save the drawing. Save the layer state in the Layer Manager. Export the layer state. In the other drawing, set your current layer to 0. Xref in the subject drawing. Put that xref on the same layer it's on in the original drawing. Import the layer state. In model space, in the layer manager select the layer state and restore. Restore the layer state twice. Regen all. Your layers should display as desired.
