- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD - Insert xref with a specific layer state into another drawing
I have saved a drawing with a named layer state. I insert it into another drawing, eve blank one, but it is not inserted with the layer state I saved it at. How can I do that?
Thanks.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
In the original drawing, put the xref on a specific layer, preferably a layer only used for xrefs, like C-XREF. Set your layers as desired. Set your current layer to 0. Save the drawing. Save the layer state in the Layer Manager. Export the layer state. In the other drawing, set your current layer to 0. Xref in the subject drawing. Put that xref on the same layer it's on in the original drawing. Import the layer state. In model space, in the layer manager select the layer state and restore. Restore the layer state twice. Regen all. Your layers should display as desired.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello Wescorr,
Thanks for the response but it is not very clear to me. Which one is the original drawing? Is it the one xref is inserted into? I have set a layer state in the xref file. I need this layer state to apply for the xref only when it is inserted in the other file.
Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What should visretain be: 0 or 1?
The inserted xref has another xref (let's call it xref1) inserted in it and it has a large number of layers. I created the layer state in xref (not xref1) but all the layers that were targeted belong to xref1. I want that layer state to apply when I insert xref into the main drawing.
thanks,
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
