pendean
en respuesta a: Anonymous
OK, so that's not how any of that works I suspect: in your screenshot there is an installer app for 2020, not 2022: you forget you had to do that 2+years ago to run their custom hatch patterns from their own custom tool? You will need to reach out to their support team https://www.keystonehardscapes.com/contactHSforms/0 If the installation guide in that folder of yours makes no sense
They also provide replacement ACAD.PAT and ACADISO.PAT files you can use under this folder (see image below): but you have to REPLACE the core one with these two by floating up this sub-folder's search path to the very top of the search path list and restart AutoCAD.
HTH
