cheryl.buck
en respuesta a: gamma.tecnicast
Hi @gamma.tecnicast,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Thank you for sharing the drawing file, I did have a chance to take a look at it. I can see that the dimensions are becoming disassociated with the viewbase views. This can occur from file corruption as you mentioned, but most commonly occurs when a model has been edited or a part has been moved.
An AUDIT did find some corruption in both files, the following Autodesk Knowledge Network (AKN) articles can help with this:
I was able to associate the dimensions afterward running an AUDIT and PURGE
If you are regularly editing your model or changing the views, you can control the visibility of the disassociated markers:
To hide the yellow alerts on dissociated dimensions in AutoCAD
To Associate or Reassociate a Dimension | AutoCAD
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
