04-27-2021
08:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-27-2021
08:39 AM
Thanks for the file. Your viewport is set to 1:50, your modelspace CANNSCALE is set to 1:1. If you set both the same you will see the same in both.
You most likely want to set MSLTSCALE to 1 and PSLTSCALE to 0 so they match. REGENALL to see the changes.
LTSCALE probably should not be set to 1, but something smaller. Experiment.
FYI your DWG is set to mm "everywhere": see for yourself, start DWGUNITS command and follow the prompts.
