817 Vistas, 4 Respuestas
type line issue scaling between model and presentation
Hi, i've been looking where ever i could but didn't get a solution for my issue : line type displays with a factor of 100 between my model and paper space. my paper space is a A3 format set in millimeters (can't change the units). the model is decimal, supposately set in meters. i can actually have line display nicely in my paper space but when on model space, you can't tell if a line is dashed or not: x100 scaling makes it impossible.
I've really tried everything (psltscale, measurment and all the bloody rest of these settings) but it just won't work and it makes me crazy.
Can anyone help ?
Thanks in advance
Ben.
Etiquetas (1)
pendean
en respuesta a: Anonymous
The program is showing you want you asked for if you have mm and meter set, is it not? share your DWG file here for us to look at for ourselves please.
en respuesta a: pendean
here's the file
pendean
Thanks for the file. Your viewport is set to 1:50, your modelspace CANNSCALE is set to 1:1. If you set both the same you will see the same in both.
You most likely want to set MSLTSCALE to 1 and PSLTSCALE to 0 so they match. REGENALL to see the changes.
LTSCALE probably should not be set to 1, but something smaller. Experiment.
FYI your DWG is set to mm "everywhere": see for yourself, start DWGUNITS command and follow the prompts.
thank you very much, it really helped. I actually had to set PSLTSCALE to 1 but otherwise it worked just perfectly, i feel kinda dumb not to have just set the drawing scale to 1:50. Thanks again !
