Kent1Cooper
en respuesta a: bcsnyder2
@bcsnyder2 wrote:
In the first line of the prompt it gives justify as "align".  Previously is was "left".   This is being changed when the prompts change.
That's because the way Aligned Text is defined in position and height and rotation is quite different from other justifications, so it asks for different things.  However that may have gotten changed [did you perhaps happen to hit A at the first prompt somehow?], just type an L at the first prompt to get back into Left-justified [or something else to get into some other justification you're accustomed to], and it should remain until you choose a different justification.  You don't even need to invoke the Justification option, but can just put in the L directly.  If it's really changing without your having done it accidentally, something else is going on -- note exactly what you're doing when it happens, if you can.
Kent Cooper, AIA
