Alfred.NESWADBA
en respuesta a: bcsnyder2
>> The prompts no longer offer the opportunity to accept or change
>> the height and it asks for the first endpoint of the text baseline
>> instead of asking for an angle
I guess you are referring to 2 different types of text objects/commands.
One command is _TEXT and the other command is _MTEXT.
Am I correct with this assumption? If yes the please find the >>>details about _TEXT<<< as well as >>>details about _MTEXT<<< to see the difference and better know when to use which type.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
