- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
AutoCAD 2021 Product Version: R.118.0.0 AutoCAD 2021.1. I will be drawing and the Text command prompts will change right in the middle of the drawing session. The standard prompts start out with an opportunity to change or accept the text height and the angle and then a prompt to enter the text. Then, at some point in the drawing session, the text command prompts will change. The prompts no longer offer the opportunity to accept or change the height and it asks for the first endpoint of the text baseline instead of asking for an angle. Even though the prompt gives the current textsize as 0.1875, when I enter text it appears in the drawing as 2.1855 inches tall.
In the first line of the prompt it gives justify as "align". Previously is was "left". This is being changed when the prompts change.
The textstyle is not changing and the height in the current textstyle is set at 0. I'm at a loss as to what is going on.
I would appreciate some help.
¡Resuelto! Ir a solución.
