rdoranZRHW4
449 Vistas, 4 Respuestas
Is there a command that squeezes or compresses objects or blocks?
I am looking for an AutoCAD command that would be similar to "Stretch" or "Scale" but would compress or expand a group of objects or a block in a singular specific direction. I have added images of what I am trying to accomplish.
dbroad
en respuesta a: rdoranZRHW4
Setting different x and y scales on a block that isn't set to uniform scale will work fine. Use the properties palette for convenience.
Architect, Registered NC, VA, SC, & GA.
rdoranZRHW4
en respuesta a: dbroad
Thank you, that's exactly what I needed for the blocks!
What about a group of objects that are not a block?
Is there a way to change the uniform scale setting on blocks?
pendean
Blocks only in AutoCAD for the effect you want to create. Sorry.
Kent1Cooper
@rdoranZRHW4 wrote:
.... What about a group of objects that are not a block?
There are routines out there for the Searching that will scale various things in only one direction.  But I think all of them put those things into a Block, scale that in one direction, and then Explode the Block.
On the second question, if you mean as you Insert one, you can set it there:
If you mean after the fact, the Properties palette will let you change scale factors, but if the Block is not defined for uniform scaling, you will need to change each of them separately.  [If you're doing only 2D work, you can probably leave the Z scale factor unchanged.]
Kent Cooper, AIA
