789 Vistas, 2 Respuestas
change my Autocad 2015 mac's interface
Hello, I would like to change my Autocad 2015 mac's interface to a Windows one. Is it possible ? if it is , how ? thanks for your answer
M_Hensley
en respuesta a: Anonymous
Not possible. AutoCAD for MAC and Windows are two different programs with different interfaces that are not interchangeable. You would have to go the bootcamp route and install Windows on your MAC then the Windows version of AutoCAD.
nrz13
As mentioned, it's not an interface you can just switch to.  However, after you install Windows using Boot Camp on your Mac, you can switch your license from the Mac version to the Windows version.  In other words, your license is not platform specific.  Both versions use the same .dwg format.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
