rapidcad
en respuesta a: nesmat.abdallah
@nesmat.abdallah , Usually problems are caused by block definitions being different in the two drawings you are copying between, but not like this - it appears there is some corruption in the data coming in which is indicated by some of your linework being stretched to different locations. Make sure that both drawings are using the same UCS, and rotation and if you are working in viewports try doing your copy from modelspace instead. If you used copy + paste I suggest you try wblocking and inserting instead. Otherwise run an audit on both drawings and choose the option to repair any problems you encounter and try again.
Let me know if any of these suggestions help.
ADN CAD Developer/Operator
