coffeejeanpaul
en respuesta a: Anonymous
Hi
I am not to sure I am on point with my feedback, but maybe it helps.
First you mention when you extrude it gives you surfaces this means your " enclosed" lines are not enclosed.
In short your end points are not connected.
Extruding the enclosed lines would for me be the quickest or  a simple press pull.
You can also copy the top lines (3d points) to the bottom elevation and loft it together.
Be sure there are 2 types of lofts surface and solids same go's for extrude.
Maybe if you have it open the full 3D panel ,there you can find more detailed 3D modelling tools.
Hope this can help you sir if it is what you are requesting.
Good Luck
