- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Menu crashes in AutoCad 2012
I managed to work out why my PC version of AutoCAd kept crashing because of problem DLLs. I have managed to set it up so that it no longer crashes.
I then installed it on my laptop, but the menu crashing still happens so
I copied the Autodesk folder completely,
the Users\AppData\...\Local\Autodesk
and Users\Appdata\...\Roaming\Autodesk
but it still crashes.
Are there any other folders i need to copy?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What fix did you implement on the desktop exactly?
Try them in the laptop yet?
This only happens with your custom menu loaded, but not stock R2012 as installed?
Your AutoCAD2012 is not designed for nor supported in Win10, is that the OS you are running on the laptop http://autode.sk/1IY4C2X
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Using Windows 10 on both machines. I used the compatabilty wizard to use it as Windows 7.
I thought it might be the cuix files but they are the same on both machines.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I don't know what has happened but my previous postings are not here.
But I have worked out myself a solution which is to change the Windows Registry so:-
HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R18.2\ACAD-A001:409\InfoCenter
InfoCenterO0
