- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous
In order to know why it's scaling the object with factor, you need to know what is annotation scale. It will scale the object with the factor "1" only when the viewport scale is set to 1:1 when moving from paper space to model space.
The reason why it scale the object is that to maintain the visual appearance after its been moved to paper space or model space.
For example if you draw a rectangle in modelspace of size 5x5 and then go to layout and create a viewport with scale 1:1 and then use the command "CHSPACE" , then the object will be moved to paperspace with scale factor of 1 and the rectangle will measure the same 5x5 in model space. Now if you change viewport scale to 1:2 and then use the command "CHSPACE" then the rectangle in paperspace will move the modelspace by scaling with scale factor of 2 since the annotation scale is set to 1:2 and now the rectangle in model space will measure 10x10 ![]()
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
