- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Text format Changes
Hi There,
When edit the title block, text format is changeing like below.
kindly help me to fix it.
#Autocad
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
just guessing: the font is not found and so a replacement font is used.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I understood that, and my guess (as long as we don't have more information) is the same, fonts may be missed.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@naidukbim wrote:
When i edit the block , That text it self changed like that dear.
Does that mean that the text was correct before you edited it, and changed only when edited? If so, it suggests that the problem is not a missing font.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try to open in Latest Autocad Version or Else use True View to Convert it
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you don't know how to use STYLE command here is an overview / tutorial https://autocadresources.autodesk.com/the-autocad-blog/text-settings-exploring-the-features-and-bene...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
When you say "edit the title block" do you mean fill in the attributes or actually edit the block with block editor?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@pendean wrote:
STYLE command, start it and fix all the defined text style in your file to match what your titleblock source DWG has for each.
That as a possibility also raises the question of whether the text was correct before editing -- they said "When edit [not "when insert"] the title block, text format is changeing," which suggests to me that it had not yet changed before editing.
Also, @naidukbim, is this a Block with Attributes, as I think we are all assuming, or possibly an Xref that you are editing with REFEDIT, or independent Text [or Mtext?] objects?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Share the file to end the guessing game.
Rob
