Kent1Cooper
en respuesta a: AIR_123
Try Searching the Customization Forum -- there may be some suggestions.  But in most situations I doubt it.  The entity data for 3D Solids is utterly inscrutable, with no way to extract useful geometric information from it.  In very limited circumstances it would be possible, for example, with a single pipe [no bends] that's orthogonally oriented, a routine could calculate the mid-line from its bounding box.  Or you might get a start by Exploding one [or a copy of it], because, for example, the end of a pipe would Explode to a Region that at least has a center point you can Osnap to.
Kent Cooper, AIA
