Alfred.NESWADBA
en respuesta a: Anonymous
>> so i have to break the polyline walls and place the door, and
>> again i would have to connect the pl's
You can already add these "room closing polylines" as well as the "wall closing polylines" inside the door block.
Then you can add hatches for walls as well as for rooms without issues.
If you need day-in day-out walls/doors/windows/rooms/.... then think about using AutoCAD Architecture. If you are on subscription then AutoCAD Architecture is part of the AutoCAD toolsets and you can install and use it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
