BeKirra
en respuesta a: imadHabash
@imadHabash wrote:
>> is there an easier way to do this of a lisp or something that would speed up my drawings?
The way here is to explode your polylines then make one window and start copy it all around and trim the wall lines beneath . In this way you don't have any overlapped lines and you don't have to make extra works with reconnecting polylines that have no advantages to keep it .
IMO op would have issues when hatching the walls on the floor plan.
@Anonymous suggest you ask some one in your office if they have any add-on that can help. It may save your time.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
