BeKirra
en respuesta a: Anonymous
Also have a look "vports" command in HELP.
Then having some practice you'll be fine.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
