03-26-2021
10:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-26-2021
10:57 AM
>> When I draw something it is not clear if its in cm
You decide the units you want to have active, if you want to draw a line with 1 length and for you this line is 1cm then you have to set the units to "Centimeter".
If you want later to draw a line with 1 Inch length then you need to draw a line with 2.54 length as this is the conversion from cm to Inch.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
