03-26-2021
04:55 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-26-2021
04:55 AM
You can turn Point objects to "face" you, whatever your view direction but still in the WCS:
(defun C:SeePoints (/ ss n pdata)
(if (setq ss (ssget '((0 . "POINT"))))
(repeat (setq n (sslength ss)); then
(setq pdata (entget (ssname ss (setq n (1- n)))))
(entmod (append pdata (list (cons 210 (getvar 'viewdir)))))
); repeat
); if
(princ)
); defun
That actually alters the Points' extrusion direction, so make sure to do it again when you go back into plan view.
Text is trickier -- if the above is used on it, it moves in the process. And this doesn't work when in a different UCS. So something with a (trans) function is needed to deal with those, but I haven't worked that out.
Kent Cooper, AIA
