945 Vistas, 2 Respuestas
Changing plane of texts and points from XY to XZ
Hello helpful people,
Right now I am struggling with plane issues. I have done a total station survey of a building and I transferred that data (points and point's names) to AutoCAD 2018 by a simple script (I use point and text command), while using WCS. Points and texts are readible by top (plan) view but whenever I am changing view (like from XY plane to XZ plane), I cannot read info I just see lines.
My question is can I make those texts and points view angle related. For example, whenever I change my plane or orbit, texts and points will follow my orientation. Or can I change the plane of the text and point (from XY to XZ), and they will look planar on the XZ plane instead of the XY plane?
Or do you have totally different ideas?
Thank you in advance
Mustafa
Etiquetas (4)
Alfred.NESWADBA
en respuesta a: Anonymous
No, not without development. AutoCAD has not a function which rotates a text object in 3d so it is always projected on screen plane.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Kent1Cooper
You can turn Point objects to "face" you, whatever your view direction but still in the WCS:
(defun C:SeePoints (/ ss n pdata)
  (if (setq ss (ssget '((0 . "POINT"))))
    (repeat (setq n (sslength ss)); then
      (setq pdata (entget (ssname ss (setq n (1- n)))))
      (entmod (append pdata (list (cons 210 (getvar 'viewdir)))))
    ); repeat
  ); if
  (princ)
); defun
That actually alters the Points' extrusion direction, so make sure to do it again when you go back into plan view.
Text is trickier -- if the above is used on it, it moves in the process.  And this doesn't work when in a different UCS.  So something with a (trans) function is needed to deal with those, but I haven't worked that out.
Kent Cooper, AIA
