en respuesta a: pendean
okay so I gave this a try.
Double check me on following your Directions:
I Created two Drawings. Both have the Company Plot Style set to be used as a reference for all Publishing both now and in the future.
- one for Opening when ready to run the Publish Command.
- one to Import the Plot Style inside of the Publish Command.
I opened the Drawing I created Specifically to run the Publish Command, Ran " PUBLISH ", selected my desired drawings, Clicked the first drawing in the list and hit CTRL+A and selected the drop down for plot styles and imported the second drawing I created specifically to Import the Plot Style, then I selected the Plot to location, and last but not least I selected the " Plotter named in Page Setup " Option and clicked publish.
RESULTS:
- I ran one of my Projects which contained 32 drawings. all of which Plotted Properly.
one thing I did Notice is that it Published all 32 Drawings under into one PDF... with the " Plotter named in page setup " option it seems I can no longer select the " Publish Options " where you can select " Multi-sheet ".. is there a Fix to that as well?
I'm going to test this on a few more Projects to make sure this Solution continues to work while I wait on your response to my Multi Sheet question..
I will update you on my findings once you reply.
