pendean
en respuesta a: Anonymous
Block whatever you need, no issue with that one.
Instead of selecting an override, then also selecting your pagestup, opt for the PLOTTER NAMED IN PAGESETUP instead, see if your issue goes away
Ideally though, you should go through this process instead
1. Launch Publish from a drawing that is not part of the publish set, but is configured with all your possible sheets and plotter options.
2. Bring in all the drawings/tabs to be published.
3. Import the pagesetup desired from the template file (in your case, one set up for exacting desired output).
4. PUBLISH.
