- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Good Morning Folks,
A few Co-Workers and Myself seem to have found an Issue with Plotting Drawings Vs. Publishing Drawings..
So,
It seems that when we use our Company Standard Plot Style and use the " PLOT " command while in the Drawing itself the PDF prints like we want it to.. Black and White with certain colors plotting certain line weights..
However, We have found that SOMETIMES if we use the " PUBLISH " Command and select all of the Drawings We're wanting to Publish to a PDF and assign the Company Standard Plot Style to them that it will Plot some of the drawings, Sometimes all of them, In color...
I know some of you would say that the Solution would be to Plot each Drawing individually within the drawing using the " PLOT " Command... and you would be correct... but I'm looking for a Fix/Explanation as to why this issue is occurring while Publishing...
To me, It's odd that the Plot Style Plots correctly individually but when Publishing with multiple drawings it seems to have a mind of its own and does not use the Plot style that's been assigned.
I can't attach the Plot Style .Ctb file itself apparently, So I have created a Blank .Dwg with the Plot Style assigned inside and attached it.
I am using AutoCAD 2018 & CadWorx Plant Professional 2018
Thank you in advance for your help,
John Rester
¡Resuelto! Ir a solución.
