- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Ver. 2021
When you open a new file, the help window is opened if you press the space bar.
I would like to kill this command.
Does anyone know how to?
FYI, I tired to change the shortcut of the keyboard at the CUI, but it does not exist.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi and Welcome to AutoCAD Forum,
Simply .. don't press space bar or enter when you open a new file !! ![]()
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
you can't tell AutoCAD to ignore keys when you pressed them (how should AutoCAD know which keys are ok and which ones it should ignore, and when should they be ignored and when not).
Fact is that <SPACE> repeats the last command, if there is no command, it starts help, but you AutoCAD can't ignore <SPACE> so you might do some modification in your ACADDOC.LSP like "if document is loaded, start line-command and cancel it" ... which means if you then have <SPACE> pressed you get the line command started ... would that be better?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Patient to doctor: Hey Doc, my shoulder hurts when I do this. [as the patient raises his arm and twists it] What can you give me to stop the pain?
Doctor to patient: You can disable the arm but you won't be able to move it ever again or you can stop doing that.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What habit was this supposed to do?
