TheCADnoob
en respuesta a: Greg.w.Witkamp
Does your solution have to be based in AutoCAD? There may be a more direct rout to your goal going through forge: https://forge.autodesk.com/
if forge looks like a solution here is some information from AU about Forge and REST : https://www.autodesk.com/autodesk-university/class/Best-Practices-Forge-REST-APIs-2017
If you cannot go that route, I would think you could get something going using Microsoft ODBC and dumping that data to an excel sheet and Data Linking that Sheet. https://blogs.autodesk.com/autocad/autocad-data-linking-exploring-features-benefits-autocad/
you may be able to go straight to excel as well depending on the way you are getting the data. I know excel has some features that interface with the web.  : https://www.howtoexcel.org/power-query/how-to-access-a-json-api-with-power-query/
CADnoob
