pendean
en respuesta a: Anonymous
MVIEW command for viewports in layouts (you added that tag, right?): usage is explained in HELP.
If your pop-up for VIEWPORTS command (modelspace) is what you are after instead, and it is not visible on screen, you can explore here on how to slide it back into view https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Dialog....
HTH
