Alfred.NESWADBA
en respuesta a: rare.eric
the character ' does not interrupt anything, it's just a prefix for a transparent command, e.g. when drawing a line and AutoCAD is asking for the next point you can use 'ZOOM to run the zoom command and then proceed with the line command. But this is how transparent commands are working, with a leading ' and this is only valid for some specific commands.
If you want to use orbit while you have a command active you don't need to start anything, just hold key <SHIFT> plus click and hold the middle mouse button and orbit is active. No key or command entering necessary at all.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
