- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> How to scale the title block combined with the drawing to
>> fit paper size ANSI D (34 x 22)?
I can only answer this question, the correct way is to draw a title-block and border which has exactly the size you need.
Then create a new layout, set it's paper-format to this size and insert the title-block (and border if separated) with a scale of 1.
After this use the existing viewport (or create a new one) and define (with zoom, pan and setting it's scale) the area of the model-space you want to see.
>> what is happening with notes and dimensions in paper space?
To answer the other questions than please upload the dwg and describe what you want to have different.
If it's just the question why you get multiple displays of one object with different size when selected then this object has assigned to be annotative + multiple annotation scales assigned (>>>details<<<).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
