260 Vistas, 1 Respuesta
03-14-2021
12:31 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-14-2021
12:31 AM
Primary dimension text alignment is changing when dual display dimension is enabled
I am facing an issue , after setting dual dimension on, primary text is automatically formatted to center.
- I enabled dual unit and selected alternate dimension below to primary in the dime style
Text alignment with dual display off
Text alignment with dual display on
- Observed the primary text alignment is automatically moved to center.
- PFA for both the files
Can anyone help me out by explaining why primary unit are aligned to center.
Thanks in advance.
Edited
03-14-2021
01:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
03-14-2021
01:42 AM
as much as i understand ... your Text placement is assign to Center , also you can change your Alternate units placement from Alternates Units >> Text placement .
Imad Habash
