03-08-2021
08:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-08-2021
08:57 AM
>> But I'm a-little confussed on what to do.
That's why I added a link to the help where you can read about named plot styles.
If you don't want to use them then you will never get this field alive, does not make sense then.
If you only want to change the color of an object (which I never would do, because the layer is the master of the color/linetype/lineweight/transparency and the object should have the settings all to "byLayer") then you can also use the property window ... select an object (or multiple) and inside the property window you can modify the settings.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
