03-08-2021
07:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-08-2021
07:20 AM
if you want to show objects in different properties you'll need to have them on different layers.
Giving an object a direct color, e.g. assigning "green" to the upper left block (ZONE 1) will remove the possibility to show this block in a different color within a different viewport/layout.
In worst case, from what I see in your drawing, you'll have 180 layers if each of the block-insertions gets its own layer. Looking to the situation you have currently means you need just 8 layers.
Please find attached a dwg with layout 1 as a sample how it could work.
And to better verify .. these 2 viewports are looking to the same objects, not to the copies as you had.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
