Yes, I have one viewport. But in that situation you discrabed, the objects in the viewport will be visible in only one color - that of the given layer. But as I mentioned above, I need to show the different small areas in a different colors. So to do that I have to create many layers and many copies of the block which I want to avoid.
With the "by block" coloring function this works perfectly, but then the large zones will be coloried as the small areas.
Sorry, but is dificult to explain.
Please see the attached DWG file. You can find in it a small example. Please mind that in my drawings I have to color-divide a thousand of objects in many large zones and each zone - to smaller areas in different color.
