assuming the block is set to a layer <> "0" and the block content has color = byblock then...
You can assign this layer in each of the viewports layer overrides for color. So in layout 1 (within the viewport) you can assign the layer of this block a color blue (VP-Color) and in another layout 2 you can assign the same layer a different VP-color.
Details for VP-color/VP overrides: >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
