- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I was trying to union that green bent object with object which you can see i the "droztukas_virsus.dwg" file, yes i know in "droztukas_virsus.dwg" file there is not solid object, because it's converted from .stl file, but when i was trying to union objects, both of them was solids, i just want to show you how that object looked like.
I know this issue is very confusing, i will try to explain it again. I was working with three objects, green bent object, green top object (on "droztukas_virsus.dwg" file you can see how it had to look like) and red bottom object. I tried to union both green objects, but instead of union it just disappeared, and UNDO command didn't returned it. So i closed the file, opened again and tried again, it disappeared again. So i closed it again, didn't saved it, and when i opened again that green top object was disappeared. I tried to union other objects in same file, it worked fine.
Does it make clear of my situation?
