- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> no no no, there was another green object
Please first start with my suggestion and run command _AUDIT ... you'll see that there are defects in the file, one result of this is that 1 of the 28 3D-Solids will be removed.
Then, when speaking "there was another object" ... please describe which of the 28 3D-Solids you are trying to union, otherwise we have to try 27^27 times until we might get the result you reached.
The previous description with "i was working with model in the center" as well as "I was working with "top" layer. I wanted to make union comand with that layer models" is also not clear (at least for me) as the center model does not have more than 1 3D-Solid on layer "top", so I can't unify 2 objects on the layer top on the center model when there only exists one object.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
