1097 Vistas, 9 Respuestas
Autocad made to disappear model after union comand
i was modeling one thing, and after using union command it disappeared. I'm attaching two files "droztukas" and "droztukas_virsus" . I was working with "droztukas" file, there you can see some models, i was working with model in the center. It had two layers "top" and "bottom". I was working with "top" layer. I wanted to make union comand with that layer models, but after union command it just disappeared, and undo command didn't recovered it. I also tried .bak file, but it was too late. On the "droztukas_virsus" file you can see that top model, which disappeared, i converted it from .stl file, that i saved day before.
Did somebody know how this happened?  Is it possible to recover it?
Etiquetas (1)
