1976 Vistas, 4 Respuestas
How to share tool palettes over OneDrive network?
At my firm, we are trying to set up our standard block library with a custom tool palette. The .dwg and .atc files are in a shared location on our OneDrive server, but it seems like AutoCAD uses absolute file paths to locate these libraries. This doesn't work for us, because our OneDrive server is located at C:\User\USERNAME, etc...
The tool palette works perfectly from my computer, but if a colleague tries to use it, the block files are "not found" and they have to re-reference the file path from their computer. That overwrites the .atc file, and then the tool palette doesn't work on my computer, and so on.
Is there any workaround that can be used on a OneDrive server?
Etiquetas (1)
Etiquetas (3)
