Alfred.NESWADBA
en respuesta a: Anonymous
>> How can I aply these text possibilities to MText,
Manually ... select the part of the text you want to assign the property and click the corresponding button inside the MTEXT-ribbon:
If you want to know how this is internally saved, then create an MTEXT with the attributes you want and look to the property window, property "Contents":
Does this help?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
