02-24-2021
07:16 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-24-2021
07:16 PM
Apart from people's comments here, do you drawing everything 1:1 scale in model space?
Attaching screenshots here does always help to people to help you. ![]()
When you say the circle looks too small, did you view your drawing on layout?
If it is the case you may have to change the viewport scale to suit.
Edit.
By looking your question again I guess you placed grid numbers on layout? If so it should be alright.
Otherwise 1/4" texts (grid numbers) in model space are definitely too small when your drawing is in 1:1 scale.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
X² + Y² = C²
