02-23-2021
12:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-23-2021
12:35 AM
...also to add...
To repair this issue you can open the block editor with this block. Add the attribute definitions (important: same name as you see when you double click the inserted block to edit the attribute values). Then close the block editor with saving and run command _ATTSYNC for this block.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
