Moshe-A
en respuesta a: vinodkl
@arazaSNXR7  hi,
To add on what @vinodkl  said ... when you insert an attribute block, the attributes become part of the block reference (insert) object, they stay even if the attributes is erased from the block definition. only when you use Block Attribute Manager (BATTMAN,  ATTSYNC) commands you actually make a sync between the two. the reason for this is to prevent accidental lost of attributes.
Moshe
