02-22-2021
07:20 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-22-2021
07:20 PM
Hi @arazaSNXR7
This happens when someone deletes the attribute inside the block in the block editor. Though the attribute is deleted it would still show it as the attribute is present. Attributes reflect the changes made in the block only when you sync them using the command "ATTSYNC". But in this case, since the block doesn't contain even a single attribute the "ATTSYNC" command doesn't work. Try this: Type in the command "INSERT" and try to insert a new block named "LED" you would see the attribute is no more inside the block ![]()
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
