arazaSNXR7
2155 Vistas, 4 Respuestas
Block shows attribute but doesn't have an attribute
I have this block in the attached drawing. When double-clicked, an attribute edit field shows up. But when I go inside the block using block editor, I don't see any attribute. When I explode the block there is no attribute inside it. When I use the burst command that text that was an attribute remains as expected.
What is going on here?
Ashhar
